hi
its very frustrating to import some small files from dropbox - some work, some not. when i choose several with “select”, then is loading loding loading … all with my ipad pro
thx for any help.
and with sycronising it is the same, doenst work …
hi
thx for any help.
Could you please upload some screenshots describing it in detail? That way I can help you better.
it is still the same one and a half year later - if i select several files in mn to import from my dropbox, it loads and loads for ages … what else can i explain. the workaround is to send each file from dropbox to mn - very tedious … and now, i cant print my files properly … with such elementary problems the app cant be recommended, besides it is a fantastic app … but in the end such things make all others things futile
