Improving user interface in research section
There are many options in the research interface such as scholar search,question search,pdf search.these are options i almost never used since i stared using margin note.similarly there are some options that some users almost never use or use less frequently so instead of keeping these options as it is,it would be better to make way for MORE CUSTOMISED URLS SO THAT USERS HAVE MORE FREEDOM TO BROWSE IN THEIR MOST FREQUENTED SITES.you can keep the old options with the relevant urls as default but should allow users to remove these urls and have our own custom urls in these options
Thank you for your feedback, we are already working on improving this issue. Currently, you can also try the community plugin MNBowser.
Hello thanks for swift reply.there is no use or need for any mnbrowser plug in here.what i am asking is very simple.currently under the DICTIONARY SEARCH option you have an option of CUSTOM URL that allows you to do key word based search in our research browser.now i request you to add the custom url to be in more options.
Example:currently under the PDF SEARCH option you currently have choices of Google, Bing.what i want is to ADD an extra CUSTOM URL choice under it and more custom urls under other options as well.
Benefits:More customised and productive search
Eg:if you currently search in Text Search in google it will simply give you information on that key word but if you provide for a custom url i can just type url to make the searches more relevant and focused for me
What i meant is i will have more freedom and customisation to use research section.
SO IN SIMPLE TERMS ADD MORE CUSTOM URLS UNDER VARIOUS OPTIONS SIMILAR TO HOW YOU CURRENTLY PROVIDED A CUSTOM URL UNDER DICTIONARY SEARCH OPTION IN RESEARCH BROWSER TO MAKE IT MORE PRODUCTIVE
Okay, we will put this matter on the agenda.
