When I select text from a pdf for it to be automatically added to the visible mind map section I’ve just had a couple of things weirdly change in terms of related settings:
If I then select the text box on the mind map so I can drag it to another part of the map, instead of moving like it has always done, it now automatically makes a copy and it’s that copy that moves.
When I first highlight the text on the pdf, now an “Insert Excerpt: Selected Position” note pop up (on the bottom left of my screenshot).
I assume I’ve accidentally changed some sort of setting or settings with my keyboard — could you please tell me how to turn these changes off? I want once again text selections on the pdf with my stylus to automatically place on the visible portion of my mind map with that Insert Except box popping up. And when I click a text box on the map to move it, I do not want a copy automatically made without me requesting it — I want the selected box to move as my stylus directs it. Thanks.
