Will it be possible to combine/merge existing imported documents or is this feature coming in the future? This would be an awesome feature if MN could achieve this.
Could you describe your exact scenario? That helps the programmers to better understand what you need.
- What document types? Iâd be happy with PDF but you might need something different.
- If PDF- do you just want to add one document at the end of another one or would you like to change the order of the pages in between (i.e. to group certain topics together)?
- Documents are PDF
- In a one study I have 7 PDFâs it would be nice to merge these PDFâs together, from the order I have them in the study.
So youâre looking for something like the native feature to merge PDF on Mac for after you have already done work in the documents?
I have a Ipad Mini only.
I want to combine the PDFâs then work on them.
If you havenât worked on them yet, I would use a separate App to âprepareâ the PDFs for import first. PDF Expert does merging only in the Pro version, unfortunately but Iâm sure there are other apps that could help you out straight away. Someone else might be able to help with suggestions for good apps.
I have already found a solution.
FoxitPhantom and GoodReader are good solutions.
Insert Blank Page is a function of 3.4.x.
And about the combination of PDFs, I agree with Nils to use a separate App to âprepareâ the PDFs for import first.
Thanks for your advices.
I find that there is one use case that support merge pdfs in app is useful when import a web page via link. Sometimes, need to collect the relavent contents from different links, so merging to one pdf is useful for further study.
Thank you for writing in. For now I can only recommend you to merge PDF in other apps before importing, but I have raised your request to our Development team, however we cannot assure a time frame when it will be put into effect. Please feel free to contact us again if you need any assistance and we will be happy to provide further help.
MarginNote-QSD
