Keyboard shortcut for "Edit Note Card"
Dear MarginNote Team,
Would it be possible to assign a keyboard shortcut to start edit the notecard and close it? Now it is a multi click effort that is often used that can be captured in a single shortcut key combination.
edit-note-card
Thank you for considering.
With Kind Regards,
Marco
Every unnecessary click = losing willpower x 2 = losing user’s satisfaction
I am not using keyboard but; in mind map mode, there should be special easy access for Apple Pencil edltting/drawing into comment section too. I need at least “2” clicks for drawing something in mind map mode (with huge file this process slows down too), “3” clicks in document mode.
2 clicks in mind map comment draw;
3 click in document mode comment drawing
-Click on cards
-Click the edit button that opened with other buttons
-Click the draw button
Or
  • succesive two tap
    -click the draw button
Especially for APPLE PENCİL users
I wish;
Editting/drawing panel should be opened with;
Just Two tap or
long press on cards with Apple Pencil :pencil:
And maybe for inspiration @admin, @Support-Team can search for “pdf cabinet” app in App Store,
Maybe for next upgrade clicking confusion substitute with “only one” long press click like this screenshot from that app
Have a great work :puzzle_piece:
Thanks for the feedback, I’ll get back to the dev department about the shortcuts and pencil gestures.
Thank you so much
Thank you for your effort. I love the product, hence my feedback for a FR.
