Currently once the card is removed any card links become broken. Some sort of feature that keeps track of broken links would be great to have. From there it is easier to relink instead of finding each card with a broken link manually.
When you mentioned the cards being “removed,” do you mean they only no longer appear in the mind map, or that they have been completely deleted?
If they have been completely deleted, I’m a bit confused about why there would be a need for a tracking feature
deleting cards should mean automatically removing any links to other nodes for that card.
A tracking feature or log may be helpful if i need to update mindmap with newer information or a newer node after deleting an older node.
When you link two cards in MarginNote 4 and then delete one of them, the link on the other card will also disappear accordingly.
If you intend to replace the original link with a new one, we’d like to suggest an alternative: why not modify the existing card instead of deleting it? This might help streamline your workflow more effectively.
This is a video of what i am talking about. It leaves behind blue links to marginnote urls that no longer exist. What i want to know is that is this a bug or normal behavior. And my suggested edit to this is like “at least leave the title of the deleted node behind instead of blue links, with some text symbol in front of it” this will at least allow me to know what i removed and do i need to make other connection remedies here. RIGHT NOW when i revisit such nodes all i see is blue hyperlinks that no longer work and i have lost all context of what wrong connection i had made in the first place.
If you are going to recommend having double way links on all the time sure that works but i want the single way link option to work as well. Also a list of broken links or some sort of simple title and text indicator for severed links would be very helpful for anyone that refines and reviews their mindmaps over time (more flexibility that way).
