hi
there is a way to disable the popupp windows when you click to a link?
( a jump from current position to a wanted linked note position requares a tree click process insted to jump directly clicking the link —when you want to navigate between notes trough links : a lote , this process is very painfull)
Do you mean cancel “the Linked Note” window and directly move to the link?
I’ll raise the request to our development team.
And you can double click the link to directly jump to the target note.
MarginNote-Chelsea
Hi
double click yes of course i am sorry
thank you support team
Best Regard
Jaspi
hi
i am sorry to insist about this topic but after some tests i realized that this double click :
- work just between nodes from the same page ( not nodes beloning to different child maps)
- sometimes is irresponsive
- i wish there will be an option to assign single click to direkt jump and double click for the popupp window( i never use this option)
- if i create reference copy the way to fallow the link, here too is with the popupp window ( no direct jump)
Best Regard
Jaspi
OK I’ll raise the request to our development team.
MarginNote-Chelsea
Hi
thank you very very mutch
Best Regards
Jaspi
hi
any hope?
If you have KeyboardMaestro, please try this macro I wrote:
Marginnote穿梭器1.0.kmmacros (10.7 KB)
Simply press Command+Shift+Space and you can travel freely between the two ends of the link.
Regards.
Hi
i use ipad pro ipados not macos
Got it, I recorded your request.
LiquidText recently upgraded that request, direct jump
It works perfectly on surface
@Edward_Support-Team @Support-Team @Jaspi
I wonder your thoughts
