Map Nodes Fail to Open PDF at Extracted Text Location
When I click on the node in the mind map (which was created by extracting text from the PDF), the PDF no longer opens at the point where the text was extracted from. I’m going crazy because this is the first time I’ve encountered this bug after years of using MarginNote (I suspect it’s due to the latest update).
I’d like to point out that I’m having this issue with every study set, and I’ve already restarted the app, cleared the buffer, removed all extensions, and restarted my iPad — but the problem persists. What should I do, guys?
Hello, you may have accidentally tapped the Link Control button. You can click on the areas highlighted in red in these two images to change the setting.
Thanks a lot, I was going crazy haha
