Margin Note not Open
Hi, I bought Margin Note 3 (MN 3) from the App Store. I installed it on my MacOS and it worked. I had to remove MN3. I have removed inclussive to your file folder.
Now I reinstalled MN3 but I try to run it and it won’t. Is there any folder from the previous installation that I need to remove to perform this new installation?
Hi Reis,
Welcome to Forum!
It’s very strange. I can’t figure out why it cannot be run. But you could try to use cleanmymac app. Or see if the folder below exists .
/System/Volumes/Data/Users/‘YourName’/Library/Containers/QReader.MarginStudyMac/Data/Documents
Yes, I was having problems with this folder. I removed the folder that was corrupted and went back to work.
Thanks.
