MarginNote 3 upgrade to MarginNote 4 Not Free anymore?
I thought it was a free upgrade.
Screenshot 2024-06-06 at 12.58.08 AM
It’s free, you can upgrade to 4 for free if you buy 3 on iPad.
I need help with this too. I was able to upgrade for free from MarginNote 3 on the iPad to MarginNote 4.
However, I am not able to upgrade for free from MarginNote 3 on macOS. On macOS, I had purchased the version of MarginNote directly from the website, and not from App Store. When I open MarginNote 4 on macOS and I click Restore Purchase to get the free upgrade, it says I need to select either the free trial or buy version 4. Why is that?
I can see that my version of MarginNote 3 for macOS is version 3.7.25 which is the latest non-App store version. But, the version available from Mac App store is v 3.7.26. For the macOS version that was bought from the independent store, will you upgrade the version of 3.7.26 so that we can upgrade to version 4 on the Mac for free?
I have the same situation here, sent multiple email to support, no reply. Really hope to upgrade margin note 3 to 4 on mac, I bought it from directly from website.
same situation. If I check updates it says there’s no one. Margin note 4 doesn’t see the 3 version available on my Mac. I also doesn’t see how can I import my MN3 archive from cloud.
@AP2022 @msack @msack Please refer to this topic, you can freely upgrade to MN4: Free upgrade from MN3 to MN4 (dmg version) on Mac
