Marginnote 5 "Data Authorization"
I just updated to Marginnote 5 from 4 on my Mac. I have an encrypted database vault. I see two behaviors when I start Marginnote 5…
  1. I get a white window with the Marginnote logo and a spinning thing that seems to go forever.
  2. Marginnote 5 starts and a window appears, “This data requires authorization before use” “Please enter the license number”
What is the license number? I get Marginnote through the Mac App store. If I click OK or Cancel, it says it can’t access the encrypted notes database.
What should I do? Thanks! – Adam
Hi Adam,
Thank you very much for reaching out, and we’re sorry for the trouble.
We haven’t received any similar reports so far, so this may be a bug. If possible, could you export the affected database and share it with us privately for investigation? Please avoid posting any sensitive data publicly.
Alternatively, could you send us a screen recording showing the issue, along with a detailed description of the steps—from upgrading to MarginNote 5 to launching it and encountering the authorization prompt? Please also include your macOS version and the exact MarginNote 5 version you’re using.
These details will help us identify the cause. Thank you for your help!
On a Mac App Store install there normally isn’t a separate MarginNote license number to enter, so I’d avoid guessing one. Before sending the database, make a full backup and try launching MN5 with the encrypted vault moved aside, or with a fresh test vault, to see whether the authorization prompt is tied specifically to the old vault. If it is, tell support that and whether the vault was synced from MN4/iCloud. That narrows it down without exposing notes.
