Merge two text highlights on ipad
It is often the case that a definition is split by a lot of words in between. This brings the need to select two pieces of highlighted texts and merge them so that when I add them to the mindmap, it generates only one node.
But on an Ipad, I was only able to do this once by accident. I do not know how I can select multiple pieces of highlighted texts (in the reading panel). Does anyone know?
Did you ever figure this out? I can’t figure out how to merge text on my iPad.
It is possible!
  1. Tap on mind map node 1 (first highlight)
  2. Tap select (bottom left)
  3. Tap on mind map node 2 (second highlight)
  4. Tap on merge
What this will do, is merge 2 separate highlights into 1 node. This also works for more than 2 nodes.
What you can also do, is drag a child node into the parent node. I’m not sure if the “drag selection to mindmap” options of “add as child” or “merge into” is working as intended.
Edit 2:
  1. Tap select on the bottom left
  2. tap on which ever nodes you want to merge.
  3. Tap merge in the black popup menu
That worked! Thanks.
Is there a way to merge that keeps the title? When I merged everything was moved into the comments.
