I would appreciate the ability to export mind maps in additional formats so that they can be imported into other mind mapping applications. Specifically, I think the Freemind (.mm) and OPML formats are probably the most universal. Thanks
I agree! Please add mind map export function.
Is this working better now since the last update?
Curious what applications people have had success in exporting to.
Guys, you can select Omnioutliner in the export option, it will export the opml format.
