There is an annoying bug in the current version: Formatting of extracted text in the edit window only partially works. Text formatted in bold remains bold after exiting the window. But for example, if I format text in red, the letters immediately turn black again as soon as you leave the window.
Hello, our test situation is normal. Would you please upload a video to describe your problem in detail? So that we can better help you
MarginNote-Bubble
O.K. here you are.
Thank you very much for your feedback. The current method of bolding and highlighting the font is in conflict, which leads to the inability to set the font color. Let's study how to solve this problem. Now you can try to use pencil to mark the font for the time being.
MN-Tester None #3
O.K. here you are.
MarginNote-Bubble
Sorry, I don’t understand, what you mean with “you can try to …”. What can I try?
I have demonstrated, that formatting bold and red is not possible. Could you show it in a short video?
What I mean is to use the brain map handwriting method to highlight the font, I hope it will be helpful to you.
