MN, in contrast to all the other apps I use, uses a significant amount of power and my iPad gets also hotter.
Kind regards,
Jerome
Kind regards,
Jerome
In the next version, MN shift the backend to Metal.And with acceleration of the GPU, power drain is supposed to be better.
Alright.
Just to be sure: the next version is 3.5, right?
Yes.the next version is 3.5
