MN4 Wrong auto grouping of cards in Table of Contents(TOC)
Hi team, thank you for creating MN4 I have been having fun using it. However, I have encountered an issue where when I draft the TOC of a PDF document, all the highlights(cards) that I make in the document doesn’t fall under the correct header.
Somehow it puts it under the latest header I created which makes creating a mind map from TOC wildly inaccurate.
I can’t seem to find a function where I can edit and place the cards under the correct header. Please advise.
update: For those who are having troubles with this, i realise that checking and unchecking Auto Add to Mindmap, as well as selecting Last position and changing it back to Grouped(by Table of contents) seem to somehow refresh the settings. It works now.
