Notes in Mindmap not added to chapter box
My book only has small number of chapters. The Mindmap is divided aling the Table of Contents. I have a lot of annotations in this book that are floating in the mindmap not as children of the chapters. How can I get them to automatically go into the chapter boxes they belong in the right order?
Hello, at present, you need to select it, drag it to the top of the brain map, and arrange it according to the document directory ~
MarginNote-Relight
So I need to take all the notes on the left and drag them into the green box at right (the document) and they will then rearrange into the chapter boxes? Or do I have to do each one manually into the proper chapter box?
Drag it to the top of the brain map, a black square will appear, and then release it
MarginNote-Relight
Thank you! This solved it.
Please could you share a screenshot of the Brain Map in MN5? Thank you.
