Me too. I just swithced over from liquid text after I used MN on my iPad with OCR. Is this feature coming, or should I go back to Liquid Text?
Honestly Liquidtext OCR is far better.
OCR works differently on the Mac and iPad. On the iPad, OCR is automatic and runs on the whole document, whereas on the Mac, it only runs when you do a capture. To make the Mac OCR work like the iPad OCR, you may need to use third-party software that can perform batch OCR on multiple document pages. Some popular options include Adobe Acrobat, Abbyy FineReader, smartengines.com, and Readiris. These programs allow you to process multiple pages simultaneously and convert scanned images into searchable text. Alternatively, you could use Apple’s built-in Automator tool to create an OCR workflow that can be applied to multiple pages or documents.
Any update one this?
Please add the same automatically OCR on the MAC as iPad!
