When cutting and pasting items in the mindmap or the outline, the items that are pasted are merged with the note that they are pasted to.
Instead of merging, is there a way to have the pasted notes be added as a child?
Hello, Marginnote currently cannot add child nodes via paste.
Hello, Edward
Is there any way this can be added? It makes rearranging notes very inconvenient.
How about you try dragging? Go to the settings interface, find "Drag & Drop", then set it to "Add as child node". Hope this helps.
