PDF Display Problem on MacBook
The Marginnote 4 app on my MacBook is not rendering the PDF document correctly. On the mind map screen, the document appears to be rendered properly. However, when I click to view the selected section in the document, only a blank page is displayed. It seems that the rendering function is not working as expected.
Hello, you may check if the PDF has lost its link. You can use iCloud sync to restore the links of these PDFs.
