PDF: problems with embedded hyperlinks
Hi Braintrust,
I tried to import a PDF planner that includes about a million hyperlinks from one part of the document to another. While many links seem to work properly, many do not so I don’t think I will be able to use the document in MN4.
This is the first time I’ve tried working with a document like this. Is there a specific reason why the links are not working properly in MN? There are zero problems with the same file in other PDF apps.
Thank you for reporting this issue. We sincerely apologize for the inconvenience you’ve experienced. To help us determine whether this is a technical issue or a configuration-related matter, could you kindly share Screenshots or screen recordings.If it’s a bug, we
may need further information, thank you for your cooperation
Best regards,
MarginNote Support Team
@Adeline
There isn’t much to show other than some links fail to work while others do.
I will try to get a screen recording.
