Possibility to auto-adjust cardsize in mindmaps
Is there a possibility to audo-adjust the size of cards in mindmaps? For example, first Layer is super big, second is big, third is normal, fourth gets smaller and so forth.
Thank you for your suggestion.What is the specific use scenario of this function? What is the reason why you think this function cannot meet your needs at present? Thank you for your support.
Thanks for your answer. In my case im working with mental disorders atm. So i have a tree, which starts at
“Mental Disorders” (First level)
“substance abuse” + “affective dissorders” + “…” (second level)
“epidemology” + “etiology” + “…” (third level)
After the third line the excerpts from my document starts. For a good overview i make the first level big and the following lines smaller and smaller. As for now, i do it by hand, dont get it exact right and it looks a little messy.
Actually by the time passed since i posted, i found a decend workaround. I marc the levels i want to have the same size, got to “size and scale” and there i can be very specific about the size of the cards. But, in this submenue it would be wonderful if i could save specific presets of cardsizes like “With 2200, Font Size 4” “With 900, Font Size 2,25” and “With 900, Font Size 1,25”.
