can it be possible to print the synthetic map?
is it possible to integrate the map on LaTex?
for example:
for example:
I am sorry that I don't know what you mean by synthetic mindmap. What do you want specifically? Thanks!
MarginNote-Sushi
hello.
I would like to know if it is possible to print the maps that are created
It is possible. All you need to do is to export to pdf and print it.
MarginNote-Sushi
I assume the image resolution is limited - perhaps just take a screen grab?
surely it would be enough to capture the screen, but an extension that allows the printing of the map tree would be more useful
now i understand how to export to pdf
