Problem with DEVONthink exports
I’ve tried to export my MarninNote-created annotations through the DEVONthink export, which is supposed to create a folder containing individual rtf / rtfd files per each annotation.
The problem is, MN’s DEVONthink export does NOT produce all of the annotations through this export format. For instance, when I export the same document via Word docx format there are 11 annotations; when I use the DEVONthink export, it only produces 3 rtf / rtfd files.
I don’t mean to be difficult – quite the opposite, since I want MrginNote to improve and succeed! – but this is why I posted my earlier suggestions re: preferred PDF formats & function, including the option to export to iThoughts, and (most importantly, perhaps) a suggestion made by many developers and users to include CSV or Tab-delim formats.
If you found some bug about DT export , you can send us the specific case(the notebook).
Yes, of course. Just guide me about what I can provide.
BTW, this is a document export, not a notebook export. But to my thinking, it shouldn’t matter – all exports should work as intended, of course. Unless I’m missing something…
Ok, so you’d like me to export it into a back up format, and send it to service@marginnote.com - correct?
Well, I sent you guys the file to the support email address. Let me know what else I can do. Thanks again!
Received, I’ll check it.
Hi, I’m also experiencing this under Version 3.2.2 (3.2.2003).
