Problem with highlight
Hi, i’m a newbie of MarginNote 3; trying to explor annote tools i’ve changed highlighter that now is a solid line (no trasparency at all). How do I return to iniziale settings? (highlighter trasparent). Thanks
You turned on the recall mode
Click setting button
Turn off “recall mode”
This should make it transparent again
Yes it works, thanks… as i said, i’ ma newbie. Could you recommend me any manual or text ?
https://forum.marginnote.com/c/Wiki/16
Here you can find what you want
But always the best way is to play around with the app till you get the point of every icon …
good luck
Tks again
Thank you!
I had the same problem. And I solved it by following your instruction.
