Hello MarginNote Team. I have a problem with merging my notes.
a) If I just drag&drop two notes, they merge but I lose color in the main note.
b) When I use “merge” with non-empty note (with comments, for example) the second note just disappears (and this is even the worst)
i dont know about the first problem that u mentioned but for the second problem turn off the title only option in settings(which is … three dots on top right of the mindmap )
Thank you! Yes, so it works correctly without SwitchTitle!
But here I have another question — is it possible to create expert(not title)card from an external source? Or create it manually with “+” button?
Thank you! Yes, so it works correctly without SwitchTitle! But here I have another question — is it possible to create expert(not title)card from an external source? Or create it manually with “+” button?
Your idea is very creative. Unfortunately, it is not possible to add cards without titles but excerpts from the outside. We have recorded your suggestions. Thank you for your feedback.
