Since I’m merging over to MN4, how does OCR Pro fit into all of this? Do I still need it in order to use OCR in MN4, or do I need to look into the new “Max” subscription? Should I cancel the OCR Pro subscription that’s on MN3 since it’s no longer being used?
You can cancel the mn3 ocr pro because the mn4 ocr is free
