Is there any plan to release or update the existent Raycast extension to work with both MN3 and/or MN4 on Mac Desktop? I (and Im sure many other users) prefer to access Notebooks through Raycast and save a ton of time by doing it that way instead of interacting with the app’s UI (which btw you made clunkier, less intuitive and uncustomizable by changing the previous Document-Study-Review left bar), so not having that update available makes it still a no no to upgrade.
One Alternative is to use Hookmark… It allows you to add bookmarks that can point to MarginNote notebooks or map elements. One advantage over the raycast extension is that it also works with many other apps.
Hello can you give scenario sample with screenshots.
Thank you so much
Of course you can use hookmark but as it will be a manual process, you will have to keep track of every new studyspace you create all the time instead of having a searching tool with access to all your spaces automatically, It wouldnt be as efficient.
A year later, this is one thing that keeps me from upgrading to MN4
