I imported a blank pdf page, I then added 6 blank pages to it (via the margin note 3 feature of adding pages) Total of 7 pages.
After I finished adding data onto these pages, I noticed my 7th page, needs to be in the 3rd page position.
I would like to rearrange this, by just dragging the 7th page to the 3rd page position. Easy.
Unfortunately, its seems margin note 3 for ios, does not offer a way for us to re-arrange pages? (or I can’t seem to find it, if there is a way) Please advise. Thank You.
We are very sorry for this inconvenience. There are certain UX improvements that we could make to make our software more easy-to-use. Thank you for sharing this tip on our forum. We will be trying to both improve our UX and UI and publish an easy-to-read user manual ASAP.
Unfortunately, there is no way to drag and drop pages to rearrange them in MarginNote 3 for iOS. However, there is a workaround:
Tap on the three dots in the top right corner of the document.
Select “Insert/Remove PDF pages”.
Tap on the “Up” or “Down” button next to the page you want to move.
Repeat steps 2 and 3 until the page is in the desired position.
Tap on “Done”.
This workaround is a bit cumbersome, but it is the only way to rearrange pages in MarginNote 3 for iOS at this time.
The developers of MarginNote have stated that they are aware of this limitation and are working on a solution. However, there is no timeline for when this solution will be available. Or you can easily rearrange your pdf files online from this website.
In the meantime, I hope this workaround is helpful.
