I have a project that i’d not respecting my document order. I sorted the documents as I wanted, but they are not showing in the correct tab order in the document slide over pane. Typically, I need to close out ans restart the app to get the changes to show (Bug…), but this time it’s not working. How can I fix this?
Thanks
Thank you for your letter. Would you please upload some screenshots or videos describing it in detail? That way I can help you better.
MarginNote-Aric
I’ve had this happen several times, but I can’t recreate the problem now. Possibly, this is only happening when a new notebook is created and multiple files are imported. Maybe an indexing is happening in the background in this case? I’ll record the workflow next time I create a new notebook and respond back. Thanks.
Thank you for your feedback. If you need help, please contact us again.
MarginNote-Aric
