[REQ] MarginNote 4 -- Tool tips, please!
An ongoing frustration with MarginNote 4 is the lack of tool tips on the macOS version. The little text labels when the pointer is hovered over a command icon for a second or two. So much of the interface in MarginNote 4 is different from MarginNote 3 (which had tool tips, BTW), that I’m wary of clicking a command icon just to see what it does, and have it mess up my work.
For an application so heavily reliant on icons, you are correct that this is a pretty severe UI oversight with reasonably large UX implications. The reason is likely that even the names of things (what is usually rendered as a tool ‘tip’) are odd and non-standard.
I don’t care. And I don’t read developer minds, either. I just want the tool tips.
Received your suggestion, has been recorded, thank you very much!
