Hello!
I would like to be able to automatically pinpoint the question and answer of a flash card in a mindmap for review, based on a symbol (Q. and A.). Does anyone know if this is is possible and if so how? It would save me a lot of trouble if I did not need to select by hand which note belongs to the question part and which to the answer…
Thanks lots for your help!
Hello, Marithalie. That depends on how your Q. and A. are organized in the mindmap card.
(A) If a card has a title, the title will become the question automatically.
(B) No title but with emphasis: the emphasis is the question(cloze).
(C ) No title and no emphasis: the first excerpt is the question.
Please provide a screenshot of your Q&A if you can. It helps a lot.
Lea
Hello! Thank you for your extensive answer:) I did not know about the emphasis method thanks!
Only I make a lot of multiple choice questions, so that does not really work for me…
I used to put the question in the title, but since you are not able to phrase the multiple choice options underneath each other, this is not really functional and also a lot of work…
Here is my method!
Hope you guys are able to work something out:)
Greetings,
Marisa
Well done! Your method is the best practice for making multiple choice questions.
Lea
Yess it really helps! But for review this system doesnt really work since you can already see the answer… Do you maybe know a solution for this? Besides the putting it in the title or highlighting? @Lea_Support-Team
Hello, Marithalie. I record a video for you to show how to review multiple-choice questions, maybe that’s what you want. It is worth noting that you need to add the card to a card deck to review it in the Review Module.
Lea
