Hi. I can’t figure out how to separate highlights that go into a mind node. I want to remove them from where they are connected to, but I can’t find a way to “unconnect” them, ie, make them float.
I’m sure that can be done, but I can’t figure it out. Thanks for any help you can provide!
Yeah marginnote somehow has a twisted way of doing this. Just hold it and drag it outside the framework parent node (if you are inside it) then leave it after you see ‘float’. If the excerpt is a child of parent tree node, then drag it to the top where you you see ‘float’
