I’m using Mac. Typically when I scroll (here i use up/down instead as an example, for right/left the problem is the same), because mac trackpad has intertia for scrolling, I usually tap gently on the trackpad to stop scrolling to let the scrolling stop at my desired position of a mindmap position (or page if it’s a document). However, when I upgrade to macos Tahoe 26.4.1, the tap causes the scrolling to resume to the original point or even earlier pages.
It’s only MarginNote who has this problem. I’ve tried to turn inertia toggle off, it does solve the problem (jumping stops) and inside margin note the scrolling doesn’t feel abrupt at all (but the other web pages does), but turning it back on makes the problem go back. I’v updated MarginNote to latest version, the problem persists.
This is really annoying. Is there a way to fix that? Thanks in advance ![]()
