In the current version of MarginNote, the Shift + Enter shortcut—which is expected to perform a line break—is instead triggering the “Submit” command for the comment/note. This makes it impossible to format text with line breaks, as the note is finalized and closed prematurely.
这边测试了是正常的,您看看是不是自己电脑的shift键盘不能用了,或者尝试重启设备和MN看看
Shift + Enter works fine in the card editor, but it doesn’t function when typing directly into a card in the mind map view.
录个视频看看您的操作呢
I have already attached a video showing how the line break works with Shift+Enter in the card editor, but it does not work in the mind map view, i.e., directly in the card’s text field.
您排查一下是不是有快捷键冲突
there are no other combinations for Shift+Enter and it works fine in every other app, for example here in the browser
Also, Option+Shift still works in Margin Note, only Shift+Enter does not work
麻烦发一下您的设备型号和系统版本号。
MacBook Air M3 2024 Tahoe 26.5
