Shortcuts for new sibling note and new child note don't work
The shortcuts for adding a new sibling note (pressing ‘enter’) or a new child note (pressing ‘tab’) do not work on my Mac. Sometimes they work but most of the time they don’t. Despite attempting to restart the app, the issue persists. Is there a solution to fix this problem?
Can it be solved under restart?
I tried, but it cannot be solved by just restarting the app. Do you mean restarting my computer?
You can try it.
Yes restarting my computer works, but this issue happens quite frequently, which means I may need to restart my computer every time I encounter the issue. Are there any other ways to solve it? or should I change any settings on my Mac?
Can you see if the input focus runs into the outline?
What does “input focus” mean? I restarted my computer 20 minutes ago, and it worked, but now the issue is here again :((
It is the location of text input. You can open the outline and enter the following text.
When I type something in the note card, it appears in the outline on the left, but only after I stop editing the note card. Do you think there are any issues with the outline settings? I don’t usually open the outline or write in it.
That may be a bug. If there is a problem, you can try to enter the text in the card, exit it, and then use tab.
Exit the card after editing it does not seem to solve the issue…The shortcuts still aren’t working.
OK, let‘s observe what it is easy to have this problem after doing it.
