Hi!
Just started using MarginNote3, and it seems great. A couple of quick questions.
- What are the intervals that the spaced repetition system uses (e.g., does the time continue to increase indefinitely if you continue to mark a flashcard as “easy”?)?
- Is it possible to customize these intervals or other behavior of the spaced repetition system?
