Hi Guys
Is spaced practice and interleaving supported in MN3?
I was thinking whether MN3 could replace a flashcard system/app like Anki?
I bought the app yesterday so I’m still very new to this.
Kind regards,
Jerome
Hi Guys
Kind regards,
Jerome
There is some algorithm based on how you rate cards on how well they are to remember: Hard, Good, Easy.
The built in flashcard tool is fairly decent. Being able to directly see the context of a flash card in the document and mind map is very helpful for retention I find.
It’s also possible to export to Anki if you prefer, which handily provides a direct link that takes you back to the relevant part of the mindmap in MarginNote - so there is pretty good integration.
Thx for Jun’s solution. By the way , we’re working on improving review system and enhance the anki-like card mnemonics.
We’re looking forward for more advices about review entrance.
Best regards,
I used 4-5 hours to really understand the app. I have also written a lot of feedback. I will post it when it’s ready.
I have the macOS and iOS version.
Kind regards,
Jerome
