Suggestion: Enable size editting on margin mode
Related tutorial:
When in margin mode, you can’t edit the size of the extended note.
Ideally, I want to put note in the right pane and the textbook on the left pane and write something simultaneously. Currently, editting in margin mode is worse than embedded mode, which is the default.
Can you please explain your needs and usage scenarios with screenshots? This is more conducive to our understanding of your needs! Thank you!
I don’t have my ipad with me right now so please understand.
What I’m saying is that when you use “margin mode”, which let you place extended note on the right side of the book rather than in the middle, its size cannot be changed (because it has to be extended horizontally) and its general experience is worse than the default extended note inserted in the middle.
