Why is the tab and multi column view function supported in study notes not generally supported? I don’t think you need to apply only in study mode.
I hope you can support it in normal document mode. Really!
In study notes, you can use the function only between documents that are tied, so the degree of freedom is low.
This is majorly because we want our users to focus on one document in document view.
If you seek for connections between documents - here is when study mode comes up!
If you wish to read multiple documents at a time, screen split is recommended!
MarginNote-QSD
Yes by the way…
It seems that the range of luck becomes too limited.
It is only possible between documents that are grouped in study mode…
If this data is vast, it lacks flexibility…
Can you please review it again
I am sorry I don't quite follow your idea - could you elaborate it?
Are you suggesting that sometimes you need to consider the connections between documents in different Mindmap Notebooks?
Then the "title link" function is highly recommended.
MarginNote-QSD
