Taking note without a book
Is it possible to use MN as a note taker, without be based on a book? And, is it possible to add a specific template instead of blank page?
Moreover, if I use a pdf as template (with Cornell method scheme as background), I have difficulty in duplicating a pdf because it is not possible to store more copies of the same document.
What I’ve done is added a pdf that is blank pages with just grid lines to mn and named it “blank”. Anytime I want to start a new mindmap without adding books yet I add that pdf so I can write on the blank page too if I wish or have it just there. Since you will probably use this blank pdf in multi-le mid maps you should always choose the do not import notes option when importing otherwise it will bring in a lot of stuff onto your mind map from other min maps that that blank pdf is in
