Please make it easier to fold Mind maps. Folding a mind map should be as easy as copying it. It shouldn’t be a hassle like it currently is, where one has to first find that small minus symbol and then hope one touches it because it is so small. The button to fold or unfold a mindmap should be bigger and perhaps slightly incease in size as one zooms out.
you can choose “expand to level” to expand quickly
Thank you, support, this is a cool function, which I didn’t know before.
OP: You can also click on each mindmap box to open the menu, go to “…” and then select collapse or expand.
