Upgrade fee from Pro to Max
I’m currently using the free trial and really enjoying the app, so I’m considering purchasing a license.
I’m deciding between the Pro Forever and Max Forever versions.
Could you please clarify the upgrade cost from Pro to Max?
Is it simply the difference of $49.99 (Max) - $12.99 (Pro) = $37?
Or is it actually cheaper to purchase the Max license directly instead of upgrading from Pro?
Thank you for your help!
It is cheaper to directly purchase the max version
