Web Clip captures problem - header overlapping with content
Problem: When capturing a web page, the header/footer get in the way of the content.
Environment:. MacOS 10.15.4 (19E266) , MarginNote Version 3.6.5 (3.6.5009)
Repro Steps:
[In Margin Note]
  1. Go to Document > Import [button] > Add Page [option] , and paste the URL https://www.scrum.org/resources/blog/scrum-master-works-three-levels
    Observation: Margin Note displays clean webpage. (1st image attached) Monosnap
  2. Click on Download [button], Margin Note downloads the page into a pdf
    Observation:
  1. When repeat steps 1 and 2 and expand Marginnot width to full page…
  • :no_entry: the start of the second page shows the header on top of the text, and the header overlaps with the content Monosnap , Monosnap
Suggestion:
  1. Is it possible to remove the ability of “pagination” – then everything would be in one page?
  2. Safari prints fine - is it possible to somehow use Safari’s print ability to print page ?
  3. Is it possible to have something like this pdffriendly to print PDF in friendly format?
    https://www.printfriendly.com/
Hello, tic.
Thank you very much for your suggestion, I have fed back to the development department about the improvements needed to save the page as a PDF. Also, if you know of any open source projects similar to PDFriendly, you are always welcome to provide us with them.
Regards.
