Weird spacing on text selection
Hi there. I am having troubles while selecting some Spanish text. When the note is created, it’s with some spacing in between the words. This didn’t happen with other similar tools and it’s holding me from buying this amazing app.
Here’s a screepshot
Thanks in advance!
it is also happening TİTLE LİNK speciality of MN
The app cant ıdentify words correctly and this makes me very angry
ıf your pdf is small, you can use online ocr tools to make your pdf render againg.
it will help app to identify
I (kind of) followed you advice: converted my PDF with an online free tool from PDF to PDF/A and worked as a charm! Thank you
