hello as title above thanks
Are you referring to the ability to locate a card back to its original document? Currently, we do not have this feature available. However, you can achieve a similar result indirectly by merging cards. For example, you can first extract a card from the document, and then merge it with the card you have created—this way, you can effectively establish a link back to the original source.
thanks for your reply. I dont want to extract anything from original document and I do want to be free at writing my crads by myself. but your idea of merging guides me to the following
1- create mind map card.
2- extract small empty rectangle area near the original location
3- merge both of them
i dont know if it will work but I will try
thanks anyway
Edit:
I tested it and it works perfectly
Glad I could help.
