Hello.
sometimes I have cards fixed as you can see in my attached screenshot. Not able to resize nor syncing my handwriting on documents to the card. let me know how to do in this case.
kind regards.
Hello.
kind regards.
Could you take a short video so we can pinpoint the problem?
You can drag the edge of the card frame to update the card (just like a green card)
I cannot that’s why I am asking…. as you can see in the video (21~23sc) if I try to drag, it just shows “research” and “more …” options without being able to drag nor update.
Okay, I understand what you mean. Can you send me the learning set privately so that we can troubleshoot the technical issue?
