Why is Margin Note removing features from the Max plan to the Pro plan?
Why is MarginNote removing features from the Max plan to the Pro plan in MarginNote 4?
I noticed that in the last three updates, they have been removing features from Max to Pro in MN4. If the Max plan is the best, how is that possible?
Hello, I may not be entirely clear on which specific aspect you are referring to. Could you provide an example?
I noticed that, too. E.g. the Card Grouping Board View. This is all mentioned in the update notes (for iOS).
I think perhaps you may be confusing “move” and “remove”. The release notes say “now available” in Pro and “moved”. All this means is that some features that were ONLY in Max are now available in Pro and Max.
Hello, after communicating with the team, they said that the increase in Pro benefits is because more benefits will be added to Max soon. We look forward to MN bringing you more experiences:)
Please let us know in the release notes if these new features require a higher version of the OS than is required by the software as a whole. There are some features (ones I don’t use anyway) that require Mac OS 15, but the software itself claims compatibility with Mac OS 12.
