Why margin note can not zoom clearly?. I hope it can improve to be better. Thank you
I missed something, can you describe it more specifically?
Thank you for your reply.
You can see if i Increasing zooming in margin note, it is blurred, fuzzed, and hard to text excerpt. But in Common view PDF, it very Clear.
So can you make document in margin note clear when increasing zoom in and easy to text Excerpt.
Thanh you very much.
Spark Slide.pdf (8.1 MB) . You can use that file to test excerpt.
This may be due to the problem of PDF encoding, you can try. In just entering the main interface of the APP, click the bottom left corner of the three points into the global settings, in the global settings of the PDF options, change the PDF rendering engine, if you are now using apple can be changed to Marginnote, if it is Marginnote try to change to apple.
I tried to switch between apple and marginote engines, but none of that works. Could you please fix this?
