Reason: This is because some pdf documents use special text encoding (probably designed to prevent copying), so that MarginNote3 cannot copy these texts
Solution: Device Excerpt After Networking (Margin Note 3 will automatically enable OCR service to correct text in ???
I use German and the OCR engine doesn’t work correctly with “German Umlaut”. Excerpts are like “ui” instead of “ü” “o” instead of “ö” and so on. If I excerpt with PDF Expert on MacOS these problems doesn’t arise. If I activate automatic OCR for rectangles it doesn’t work. I need to do it manually. The online OCR makes no difference at all. The “?” are away, but the OCR for the German is faulty.
